Date/Time: Fri, 03 May 2024 05:16:44 +0000
Footprint messed up
View Count: 805
[2018-06-10 11:57:17] |
Rassitude - Posts: 33 |
The footprint is suddenly messed up, has anything changed? Cheers |
[2018-06-10 12:11:27] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-10 12:32:08] |
File attached
[2018-06-10 15:52:41] |
Happens with all UT
[2018-06-10 22:07:56] |
Check the Volume at Price Multiplier setting: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) Make sure it is set to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
