Date/Time: Sat, 18 May 2024 15:24:47 +0000
Storing Time and Sales Depth data
View Count: 664
[2018-06-08 18:07:52] |
SekFutures - Posts: 1 |
This is mostly regarding the Bid and Ask depth bar study. I often use the Time and Sales as my source data for this study and find the Bid depth vs Ask Depth mode to be useful. Is there anyway to store this data historically so anytime I re-open an intraday chart I can see this information from previous sessions? Thanks |
[2018-06-09 00:23:44] |
The data is maintained while Sierra Chart is running but otherwise it cannot be stored.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 17:21:10
[2018-06-10 19:28:25] |
User132748 - Posts: 159 |
What does it mean "sierrachart sessions"?
[2018-06-15 17:20:06] |
We just mean from the time you start Sierra Chart until you exit.
