Date/Time: Sat, 04 May 2024 12:42:26 +0000
... to add support for OpenGL.
View Count: 1924
[2018-06-08 17:57:18] |
ganz - Posts: 1048 |
To improve graphics performance we are going to add support for OpenGL.
fyi: https://developer.apple.com/macos/whats-new/Deprecation of OpenGL and OpenCL
Apps built using OpenGL and OpenCL will continue to run in macOS 10.14, but these legacy technologies are deprecated in macOS 10.14. |
[2018-06-08 18:57:20] |
Apple is moving over to Metal, which is an Apple specific API. OpenGL is by no means deprecated (outside of Apple). Anyway, OpenGL is going to be an option. The Windows GDI will still be supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 18:57:37
[2018-08-08 14:03:46] |
samual sprat - Posts: 343 |
Hi Is the new opengl implementation of sierra due soon? is there an estimated eta?
[2018-08-08 18:39:15] |
Should be before the end of the year. The intent is it will be an option that can be enabled. We have finally completed the underlying work, to make this possible. This is one of those items, that does not show up on What is New but is a lot of work.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-08 18:39:35
[2018-08-30 20:24:55] |
Rexz - Posts: 20 |
Will OpenGL help with a lot of objects being drawn on screen like marketdepth being zoomed out etc? I can easily get fps or rendering lag if lots of market levels are displayed. Thanks |
[2018-08-30 21:56:58] |
Yes to the extent of the issue being unrelated to text. Because OpenGL does not support text. That still has to be drawn using the standard Windows GDI.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-30 21:57:31
[2018-08-31 17:15:31] |
gomifromparis - Posts: 244 |
I hope you guys allow us to use some parts of your OpenGL API. I make a heavy use of custom graphics, my studies are coded using my own graphical abstraction layer, so they can work on NT7 and sierra (using a GDI implementation) and NT8 (using a SharpDX implementation). So I hope you guys can expose parts of your graphic lib so we can bypass GDI and use OpenGL primitives directly in a custom plot study. Basically here are my needs :-) void DrawText(string text, GomFont font, float x, float y, Color color, GomTextAlignment HorizAlign, GomTextAlignment VerticAlign); SizeF MeasureString(string text, GomFont font); void FillRectangle(Color color, float x, float y, float width, float height); void DrawRectangle(GomPenParams pen, float x, float y, float width, float height); void DrawLine(GomPenParams pen, float x1, float y1, float x2, float y2); void DrawLines(GomPenParams pen, List<PointF> points); void DrawPolygon(GomPenParams pen, List<PointF> points); void FillPolygon(Color color, List<PointF> points); Thanks ! |
[2018-09-01 10:52:41] |
SC Support imho, it might be worth to add multi layer support 4ex: to update last bar only, to separate crosshair an so on |
[2019-01-28 23:51:44] |
SC Support Should be before the end of the year. any news? thnx. |
[2019-01-28 23:58:31] |
This project continues to be worked on by one of our Russian developers. They are reporting significant performance gains with OpenGL. There are a lot of details to this implementation though. We are not sure when a release would be possible. And there will be an option to still use the Windows GDI as well because perhaps the actual final rendering may not be what some users are used to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 23:58:42
[2019-03-01 12:31:57] |
Hi, any news on this piece of work? Thanks S |
[2019-07-08 18:22:01] |
There is still more work to do with OpenGL. It is not yet ready for use by users.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-08 18:22:10
