Date/Time: Fri, 03 May 2024 03:51:24 +0000
TPO profiles disappear when switching to
View Count: 669
[2018-06-08 16:38:44] |
Zosimus - Posts: 345 |
After upgrading to 1760 I see that when I switch a TPO chart to Letters/Blocks in Own Columns - All Profiles mode the TPO profiles disappear (see attached image) and also the Caught exception in c_Chart::GraphDataForGraph message starts popping on the log. When I switch the TPO chart back to regular profile mode the error messages stop and the profiles appear again.
[2018-06-08 18:45:17] |
This is now fixed. We are putting out version 1761 in about 15 minutes. It is not something we observed during testing. It simply related to an array bounds violation due to a 64-bit unsigned type that should have been signed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 18:45:54
