Date/Time: Sun, 19 May 2024 22:10:48 +0000
Potential PNL on Order Lines
View Count: 808
[2018-06-08 16:27:52] |
infpz - Posts: 826 |
Possible to see the hypothetical loss if 7121.50 (stop loss) were hit in this example, on the line with the rest of the items? In this case it would be -$800 (40 NQ points). When you move the stop, you see the point values move as you move the stop- would like to see the $ amount there as well, or at least a choice for it. http://www.sierrachart.com/image.php?Image=1528474522720.png |
[2018-06-08 19:07:26] |
Yes we can add an option for that.
[2018-06-24 18:38:19] |
This should be out by next week.
[2018-10-22 14:23:14] |
Curious to see if this was implemented? If so can you please link me to the proper documents.
[2018-10-22 17:26:45] |
Yes. Refer to: Global Trade Settings Windows: Attached Order P/L Always (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
