Date/Time: Tue, 07 May 2024 08:35:27 +0000
Stagger Exits When Scaling In?
View Count: 1000
[2018-06-08 15:05:55] |
User993067 - Posts: 142 |
Is there an option when scaling in to have the stop losses grouped as single exit...and then have the profit targets staggered based on the configuration of my bracket order management...or ATM? Example say I initially buy 1 contract with a 8 tick stop and 6 tick exit...I place an additional buy stop (same exit criteria) for 2 more contracts 2 ticks above entry point...can the stop losses be grouped as one so I can manage the stops as a single unit...without also grouping the targets? currently if support scale in is not checked these are all separate orders...both stop and target...but when it is checked both stops and targets are grouped...I would like to have the stops grouped and targets to be staggered according to entry point. Is this possible? Thanks, LG |
[2018-06-09 08:42:32] |
We understand what you want. No, this kind of scale in set up is not possible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-09 08:42:42
