Date/Time: Sat, 04 May 2024 22:32:14 +0000
Market if Touched orders
View Count: 2157
[2018-06-07 23:58:57] |
User162290 - Posts: 11 |
Hi, I saw at sierra charts that they offer Market if touched but then it says: This order type is not supported with all of the supported Trading services that Sierra Chart works with. does that mean that it might not work with AMP brokerage ? thank you kevin ************************************************* AMP answered me the following: Hello Kevin, I believe CQG data feed does support MIT orders however to verify this for sierra charts you may want to submit a support board inquiry to verify with their support staff. You can do so from this link if you have a sierra charts account. |
[2018-06-08 10:52:46] |
This order type really depends on the particular exchange but if it is not supported, then Sierra Chart has a Market if Touched-Client managed order which can be used instead: Order Types: Market if Touched - Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 11:30:54
