Date/Time: Mon, 06 May 2024 18:32:29 +0000
bid/ask depth bars
View Count: 3149
[2013-10-13 21:41:43] |
SgtJ - Posts: 154 |
We have a few calculation methods for this study. Can you add the ability to SUM: 1. Just the Ask side. 2. Just the Bid side. Two subgraphs, abv/below zero line similar to the way the "bid volume vs ask volume" study displays. thx see pic Date Time Of Last Edit: 2013-10-13 21:45:36
bidask depthbars.png / V - Attached On 2013-10-13 21:41:31 UTC - Size: 6.82 KB - 709 views |
[2013-10-15 01:48:45] |
We will see about this.
[2013-10-15 19:03:38] |
Al SC Developer - Posts: 434 |
In ver 1036, there is a new option "Bid Depth vs Ask Depth", which will show the bid and ask depth in a similar fashion as the bid volume vs ask volume study.
[2013-12-03 15:52:31] |
SgtJ - Posts: 154 |
Al, thanks for the addition. I think what I said above was a little misleading re bid vs ask study. W/ the new option was hoping it would still display in a fashion that showed the OHLC of the individual bars similar to how the other depth options work...is that a doable change/option?
[2013-12-05 19:46:19] |
SgtJ - Posts: 154 |
Also being able to hide/ignore the difference subgraph...currently can't be hidden.
[2013-12-13 13:38:34] |
ganz - Posts: 1048 |
Hello SC Support http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s213 Is this correct? Total Ask Depth and Total Bid Depth are calculated every time there is a change with market depth.
Or is this a snapshot of Total Ask Depth and Total Bid Depth if a trade takes place?Thank you. |
[2014-01-07 22:41:55] |
In ver 1075, two new options were added to match your original request (Sum Bid Side and Sum Ask Side). These will display with OHLC bars. Also, the difference sub-graph (and others) can be changed/hidden.
[2014-01-08 01:45:42] |
Or is this a snapshot of Total Ask Depth and Total Bid Depth if a trade takes place? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
