Date/Time: Mon, 29 Apr 2024 16:43:30 +0000
Messeges Under Help
View Count: 1188
[2013-10-13 16:38:23] |
Frank A Errico SR - Posts: 22 |
"This file does not have a program associated with it for performing this action. Please install a program or if one is already installed, create an association in the Default Programs control panel." I have windows 8 and use Google browser. I would appreciate more specific assistance with this...Thank you |
[2013-10-13 19:18:27] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails73.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
