Date/Time: Mon, 06 May 2024 16:18:12 +0000
volume profile and tpo
View Count: 790
[2018-06-06 23:03:58] |
User99934 - Posts: 227 |
http://www.sierrachart.com/image.php?Image=1528325608103.png The length of the volume bars when set to all visible bars is not correct using TPO. The 18:20 bar compared to others is an example. |
[2018-06-07 00:15:27] |
Are you referring to the volume bars or to the TPO blocks?
[2018-06-07 00:19:01] |
the volume bars.
[2018-06-07 15:19:38] |
John - SC Support - Posts: 31400 |
We are not able to reproduce this. Can you please attach the chartbook with the single chart in it that shows this issue. We can then review the settings and see why this may be happening. To attach the Chartbook, follow the instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
