Date/Time: Sun, 05 May 2024 15:29:00 +0000
Study Parameters Showing Up At Study Summary Even Though They Are Not Ticked To Do So
View Count: 886
[2018-06-06 14:17:02] |
Alberto Gauer - Posts: 121 |
Hi, I´m trying to configure the study summary to my liking, but I have encountered a problem. I wanted to have only one parameter of one instance of the study showing at the summary, in this case the "open" parameter of the OHLC study (in this study the reference is the current day). But even though I only ticked the "open" parameter to show at the summary, the "close" parameter is showing, and I don´t want it. I duplicated the study so this second instance would be using the previous day as a reference, so I could choose the "close" parameter of the previous day to show at summary, but I can´t do it, it seems like the study summary only wants to use one study of the chart (I mean, when you have the same study duplicated). Image attached. |
STUDY SUMMARY SUPPORT.png / V - Attached On 2018-06-06 14:16:31 UTC - Size: 568.04 KB - 258 views |
[2018-06-07 06:00:01] |
As is explained in the Introduction section here: Study Summary Window: Introduction If you want to have different instances of the same study on the same chart included in the Study Summary, you need to give them a different names through the Short Name setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-07 06:00:24
[2018-06-07 23:00:52] |
Oh I see, ok. You enlightened me about something I overlooked, now I can have two instances of same study in same chart showing up in the study summary. But as I stated in my original post, the study summary "doesn´t wanna have" only 1 parameter of the OHLC study showing up, it "wants" at least 2? Check for yourself. Try to leave only the Open or Close parameter ticked, and the study summary will always show both. I wanted to have only one OPEN column (for the current day), and only one CLOSE column (previous day close)... As of now I´m obligated to have 4 columns (2 opens and 2 closes), for sake of organization it takes screen space, and I have to look to info I don´t want to. Date Time Of Last Edit: 2018-06-07 23:02:01
[2018-06-08 01:55:05] |
the study summary "doesn´t wanna have" only 1 parameter of the OHLC study showing up, it "wants" at least 2? If among the used instances of this particular study on the charts that are on the Study Summary window, those two Subgraphs are enabled to be used on the Study Summary, then they will both display.Even if just one of the subgraphs on one of the studies is set to be included in the Study Summary and on another instance of the study, the other Subgraph is set to be included in the Study Summary, then they both will be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 01:56:17
