Date/Time: Fri, 03 May 2024 22:59:33 +0000
[Programming Help] - Delta Divergence & POC rejection
View Count: 1287
[2018-06-06 06:03:29] |
User523480 - Posts: 18 |
Hello, Is it possible with the studies to generate an alert or signal every time a delta divergence is detected after closing bar (e.g Up-bar & delta negativ || Down-bar & delta positiv) Is it possible to generate an alert or signal in case of a user-defined POC rejection (e.g down-bar and POC in the upper 3 lines of the bar || up-bar and POC in the lower 3 lines of the bar) Thanks |
[2018-06-06 12:34:28] |
Alberto Gauer - Posts: 121 |
Check infinity future´s channel on youtube, they got loads of sierra tutorial vídeos, in a lot of them they show how to create various kinds of alerts, just copy the formulas and change them.
Date Time Of Last Edit: 2018-06-06 12:35:05
[2018-06-06 12:59:35] |
I checked all their videos but none of them helped me to achieve this.
[2018-06-06 14:09:16] |
I see. Well, there must be a formula for an all time high and all time low situation, thing is that for the delta divergence when it´s not an all time high, it´s a very subjective thing, what may be a higher high for you that could configure a delta divergence might not be for me, how to decide when it´s high enough to configure a delta divergence? It´s complicated. Either way, I tried this delta divergence approach and to me it doesn´t give you a better edge than, let´s say, a moving average crossover does...
[2018-06-06 14:29:22] |
binaryduke - Posts: 360 |
www.emojitrading.com/indicators/delta-divergence www.emojitrading.com/indicators/poc-at-extreme will both deliver these types of indications and corresponding alerts. |
[2018-06-06 15:34:38] |
Yeah I like this dude. I have configured sierra numbers bars watching his vídeos. If you are an infinity futures´s client they will certainly help you with that formula, Patrick is an expert. What you are trying to achieve is using the color background on alert study, there must be a formula where you can choose to color the background when delta is negative and then you can experiment with diferente settings for what you consider a higher high or a top... Must be something like closing price higher then previous X number of candles. |
