Date/Time: Mon, 29 Apr 2024 02:44:29 +0000
High/Low on a overlayed chart
View Count: 1402
[2013-10-13 08:40:25] |
toews&kane - Posts: 209 |
Hi there, I overlayed a chart to the main graph. The overlayed is a tick chart which had a high/low study to capture the high and low of a period and it will draw a horizonatal line through it. I have also added a spreadsheet study for trading on this main chart. The problem is the high/low is returned on the scale of the main graph and not the tick chart. Is there anyway around this? I want to do something like if tick> high tick of the day then...do this. But I found that it fails because the high tick is recorded on the main chart's scale? Cheers |
[2013-10-13 19:06:08] |
M5amhan - Posts: 468 |
you have to reference the overlay, not the main price graph.. you should be able to find it by scrolling right on the spreadsheet
[2013-10-13 19:19:13] |
You need to base the High/Low for Time Period study on the Overlay study that you are using: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
