Date/Time: Sun, 28 Apr 2024 10:14:46 +0000
Volume profile Charts
View Count: 534
[2018-06-05 23:09:32] |
User163689 - Posts: 29 |
Did something change with the way these charts are using memory? I used to have 4 different chartbooks open and use low to mid 300MB for all of them now 1 chartbook open is 592MB. Settings for all have stayed same no dates changed to add more data total now 1842MB for 4 chartbooks
[2018-06-05 23:30:40] |
Okay we think we know what the problem is. Although we would not expect that much additional memory use. We will have this resolved later this evening with another release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-05 23:31:02
[2018-06-06 00:08:41] |
not sure if this helps but rolled back to 1734 and now back to 352MB saw your post after i rolled back
[2018-06-06 00:54:20] |
Yes we did already correct the problem but did not change the version number. Really we were quite surprised by this, but apparently the memory use was adding up from one particular object that was allocating an unnecessary large amount. This object is used to hold the volume data at each price level for the individual volume and TPO profiles.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-06 00:55:52
