Date/Time: Fri, 03 May 2024 17:30:50 +0000
Email alert screenshot
View Count: 1134
[2018-06-05 16:59:44] |
User565999 - Posts: 9 |
Hi team, It is possible to send an email alert with custom subject and chart screenshot inside. When its not possible, can it be programmed via ACSIL? If not, is it possible to make a screenshot and send it via webhook? Thank you so much |
[2018-06-05 21:14:26] |
No, this is not supported but you can use ACSIL to take an image of the chart. Refer to: sc.SaveChartImageToFileExtended() Also, refer to: sc.MakeHTTPRequest() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
