Date/Time: Sun, 05 May 2024 12:38:01 +0000
Spread/Ratio Line & Symbol Support
View Count: 938
[2018-06-05 16:45:27] |
User667431 - Posts: 3 |
Hello, I wanted to find out if anyone knows if you can plot a spread or ratio line between two different symbols on a chart or overlay such a ratio/spread on an existing chart? Also, does Sierra supports ETF data. For example, if I subscribe for NYSE data, I should be able to plot symbols like IWM, USO, etc., correct? Thanks! J. |
[2018-06-05 20:54:28] |
Use the Difference (Bar) study: Difference (Bar or Single Line) You can load additional symbols into the chart through this study: Add Additional Symbol Also, does Sierra supports ETF data. For example, if I subscribe for NYSE data, I should be able to plot symbols like IWM, USO, etc., correct? Here are the instructions: Sierra Chart Exchange Data Feed: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-05 20:55:24
