Date/Time: Mon, 06 May 2024 16:40:46 +0000
CME Data for Trial
View Count: 932
[2018-06-05 09:37:18] |
User673946 - Posts: 1 |
I had an existing account from last year and am trying to get live data before going live using Sierra. On a previous support ticket I was told I could get data until the end of the month, but as it was only a couple days was suggested to wait until the new month started. I seem to be going in circles here. Was sent instructions on how to setup, but going through the setup is says to contact support if you had previously had Sierra setup on your computer. Any help would be appreciated. Thank you, Peter Date Time Of Last Edit: 2018-06-05 09:49:07
[2018-06-05 09:49:41] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above, completely before you ask further questions about real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
