Date/Time: Fri, 03 May 2024 21:54:59 +0000
SC1757 64bits - TPO wrong open and close with developped form
View Count: 996
[2018-06-05 09:22:35] |
User877753 - Posts: 152 |
Dear SC support team, Some trouble with TPO (SC 1757 64 bits) : with "letters/blocks in own column" selected, Open Market Color (SG18) and Last trade Arrow "SG20" are defintely not wher they should be, or simply missing. http://www.sierrachart.com/image.php?Image=1528190477768.png Thanks in advance, Best regards, JM |
[2018-06-05 09:53:39] |
We are checking on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-05 10:31:00
[2018-06-05 10:31:47] |
We have determined the reason for the problem and will have it all resolved by the end of the day. It has to do with optimizations for TPO profiles and a problem created with determining the horizontal indexes for different components of the profiles. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
