Date/Time: Mon, 29 Apr 2024 11:34:19 +0000
how to download 10 years data
View Count: 766
[2018-06-02 08:46:20] |
User359273 - Posts: 26 |
Hello, I try to download 10 years historical data, but it is not successful during the past weeks. I attached the picture and help me check it. thanks ! |
[2018-06-02 22:34:54] |
Did you want historical Daily or Intraday data? And for what symbol? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-27 05:21:06] |
Hello, Now I have a new question:I use range per bar -True(in ticks), I want to every fifty bars integrate into one Vbp. when open Vbp, how to select? like: 1:Draw mode: Volume profiles 2: Ticks per volume Bar ? 3:volume Grahp Period Type ? 4:how to set time period ! ? I just need fifty bars (range bar),don't consider the time. |
[2018-09-27 21:49:26] |
In order to do this, use the settings as defined here: Volume By Price Study: One Volume Profile per Chart Bar But set the Number of Bars for 'Based on Bar Count' to 50. And do not worry about the number of days to load. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
