Date/Time: Tue, 30 Apr 2024 16:39:42 +0000
possible display problem
View Count: 1198
[2013-10-11 20:32:29] |
M5amhan - Posts: 468 |
hello i have noticed that the "dash" line style will not work on studies when using a thickness greater than 1. this will work on drawing tools though. could this be fixed? here is an example side by side: http://www.sierrachart.com/image.php?l=1381523533644.png thanks |
[2013-10-14 12:47:57] |
could you please look at this? i am sure it is just a small problem because it used to work thanks |
[2013-10-15 02:46:59] |
There is no practical solution to this because the line is not a continuous line. It is multiple smaller lines, so it will appear solid due to the extra thickness.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-15 02:47:29
