Date/Time: Mon, 29 Apr 2024 13:13:28 +0000
User defined reference lines with labels
View Count: 1289
[2013-10-11 18:14:41] |
emp0804 - Posts: 31 |
Is there an option in SC that allows a group of reference lines with labels? Image of IRT |
Custom reference lines.jpg / V - Attached On 2013-10-11 18:12:55 UTC - Size: 14.77 KB - 434 views Attachment Deleted. |
[2013-10-11 18:28:51] |
ganz - Posts: 1048 |
emp0804 F6 -> Horizontal Lines http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s113 |
[2013-10-11 18:46:26] |
Thanks Ganz!! You helped me out once again!!
[2013-10-14 17:33:12] |
To set up labels on studies, refer to: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#NameValueLabels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
