Date/Time: Mon, 06 May 2024 12:14:27 +0000
Symbol for Russell 2000 futures
View Count: 880
[2018-06-01 02:47:03] |
User88 - Posts: 40 |
I can't get any historical daily data for RJU18 (Russell 2000 Sep 2018 contract). Barchart page uses QRU18 as their symbol. When I used that symbol, I got the following message: HD Request # 111 | Error downloading historical Daily data for QRU18. The symbol is not a supported symbol for this historical data service. | 2018-05-31 22:39:26
What is the correct symbol that I should use? Thanks. |
[2018-06-01 04:00:29] |
Use RTYU18. You should also update to the current version following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-01 04:00:41
[2018-06-01 04:11:19] |
I updated to v1750, and tried RTYU18 but it doesn't show any historical daily data as well.
[2018-06-01 04:21:01] |
Select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-01 06:27:46] |
It works now. Thank you
