Date/Time: Mon, 29 Apr 2024 09:47:17 +0000
Number Bars Imbalances
View Count: 1602
[2018-05-31 16:02:34] |
User311951 - Posts: 31 |
Hi, I have created a numbers bar chart and colour-coded certain numbers using the Column 1 Text Colouring Method "based on diagonal dominant side AskVol BidVol percentage". I was wondering if there was a way to make these numbers bold or another sized font as opposed to just having them coloured? This will help the numbers stand out more. Thanks |
[2018-05-31 16:36:17] |
No, this is not supported, but have look at this study to draw markers: Volume at Price Threshold Alert V2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-31 16:38:08
