Date/Time: Thu, 02 May 2024 17:15:10 +0000
moving computer
View Count: 841
[2018-05-31 08:35:26] |
User339776 - Posts: 22 |
Hi what is the best way to re set up sierra on a new computer, while taking all my setups and settings with me? last time i did i this i just took the data folder with me but that didn't include my settings etc. Please advise, it would be great to take the right files with me and be able to open sierra on new pc and everything look the same Thanks in advance |
[2018-05-31 09:01:16] |
Refer to this help topic about this: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation You can do exactly what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-31 09:56:12] |
Great. Thank you
