Date/Time: Mon, 29 Apr 2024 05:48:46 +0000
question on sc.BaseDataEndDateTime
View Count: 768
[2018-05-30 19:57:41] |
User30743 - Posts: 364 |
hi, i would like to ask why sc.BaseDataEndDateTime returns such a strange results. when i have a 2 minute charts, i would assume that each bar in the chart stars at 0:02:00 and ends at 0:03:59. yet, it doesnt. the start time (fce sc.BaseDateTimeIn) of each bar i correct, but the ending timestamp (fce sc.BaseDataEndDateTime) is everytime quite strange.. why is it so? |
baseDataEndDateTime.png / V - Attached On 2018-05-30 19:57:34 UTC - Size: 64.25 KB - 221 views |
[2018-05-30 20:53:34] |
It will contain the last trade time within the bar. That is not necessarily at the last second or millisecond.
[2018-05-31 13:02:51] |
ok i got it. btw. when it comes to miliseconds, you claim the ranges are 0-999 but what i actually get is only range from 0-10.. any reason why? GetMicroSeconds() is not supported at all and you should better delete it from the documentantion Date Time Of Last Edit: 2018-05-31 13:05:37
Attachment Deleted. |
[2018-05-31 19:21:43] |
This section here answers the questions: http://www.sierrachart.com/index.php?page=doc/SCDateTime.html#ValidRanges Microsecond support will come. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
