Date/Time: Thu, 02 May 2024 14:23:38 +0000
2 or more contraact trades
View Count: 672
[2018-05-30 17:00:00] |
User848740 - Posts: 12 |
Worked all morning and no success. Both contracts start out with 10 tick stops Contract or group 1 has a target of 4 ticks The target on Group two is 10 ticks. Condition" When trade hits first target of four ticks thee stop on group two goes to break-even. How do I do this? I would pay a fee if I could get someone to get on my computer and set it up for me. I am your 94 year old trader with very bad vision. Fred Any videos? |
[2018-05-30 19:42:00] |
Xfanman1 - Posts: 320 |
Fred, put the attached config file into your Sierra Chart Data folder, it should do what you are asking. If you want something changed I'd be happy to help you if I'm able. -- Scott |
2Target-4-10AdjustableStop.twconfig - Attached On 2018-05-30 19:41:52 UTC - Size: 6.52 KB - 215 views |
[2018-05-30 19:46:18] |
The post above is a trade window configuration file from a user hopefully with the configuration that you have requested. Here are instructions to use it: Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
