Date/Time: Sun, 19 May 2024 19:23:00 +0000
Attach/detach time and sales windows to the chart doesnt work
View Count: 1585
[2018-05-30 14:23:00] |
nioko54130 - Posts: 108 |
hi dear support! the function "attach/detach time and sales window" on the chart doens't work correclty when we click on the button, it doesn't change anything in the 1753 version. Could you check this please? thank'es |
[2018-05-30 18:36:52] |
This is not designed to attach or detach to the chart but detach the Time and Sales window from the main Sierra Chart window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-13 18:47:57
[2018-05-30 19:32:13] |
oh ok thanks for your reply |
[2018-06-13 16:53:16] |
traderacefly - Posts: 57 |
Since each Times and Sales window is associated with the selected chart when a T&S window is opened, would it be possible to "attach" the T&S window to that chart?? For example, like how one is able to attach a trade window to a chart. I understand that this has not been possible in the past but since you've added the option to detach/attach the window now, just wondering if that is a feature that could be added as well. This would be invaluable for us that open chartbooks on computers with different monitor setups. For example, I use a virtual machine and RDP to connect to Sierra Chart at home with multiple monitors. While I am traveling I use a laptop and connecting to the VM causes the Time & Sales windows to move to random places and they have to be manually moved every time I switch computers. Thanks for your consideration. Have a great day! Date Time Of Last Edit: 2018-06-13 17:02:36
[2018-06-13 18:49:10] |
No, this is not supported or planned.
