Date/Time: Sat, 18 May 2024 23:41:56 +0000
1753 Aligned renko issue
View Count: 667
[2018-05-30 10:54:09] |
ertrader - Posts: 648 |
Hi support... Renko, Flex Renko and Aligned renko in 1753 appears to not properly read chart settings. Always defaults to lowest tick no matter what is entered when creating a new chart or changing a current chart. To work around this, each time a value is changed in setting, I tried deleting and redownloading... this seems to work but needs to be done each time chart period value changes. Note scale on right side. http://www.sierrachart.com/image.php?Image=1527677519449.png Date Time Of Last Edit: 2018-05-30 11:08:23
[2018-05-30 10:56:46] |
Here are the settings
Date Time Of Last Edit: 2018-05-30 10:56:59
[2018-05-30 20:33:53] |
We cannot reproduce any problem like this with Aligned Renko bars. Perhaps there was some minor inadvertent issue that we were not aware of that has already been corrected. Wait for the next release.
[2018-05-31 10:17:49] |
This issue is resolved in 1754
[2018-05-31 10:24:44] |
Nothing was done to resolve it and we never observed it. So we really do not understand the basis of it to begin with.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-31 10:24:58
