Date/Time: Sat, 04 May 2024 03:22:24 +0000
TPO Daily weekly
View Count: 1474
[2013-10-11 07:31:32] |
User594026521 - Posts: 2 |
Hello, i like to use TPO. and i switch between daily and weekly many times. maybe you can make in next updade buttons for toolbar for it? Or the options Daily /weekly if I click the right mouse button? maybe you have some another ideas to make it faster? thank you for help in advance Greetings |
[2013-10-13 20:25:05] |
There is a way to do this. Create 2 different Study Collections each with the TPO Profile Chart configuration that you want. You then can switch between them through the Analysis menu. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
