Date/Time: Fri, 03 May 2024 12:34:17 +0000
Cancel Last Order?
View Count: 851
[2018-05-25 13:39:03] |
mosheikh1996 - Posts: 3 |
Hi, Is there any command available to cancel only the last order posted instead of the "Cancel All" command? If not, could this possibly be looked into as a part of a future update? Thank you. |
[2018-05-25 18:49:21] |
No, and we do not foresee doing this.
[2020-11-13 18:25:52] |
User360981 - Posts: 4 |
I would be interested in this also.
