Date/Time: Thu, 02 May 2024 04:54:01 +0000
data and settings after formatting windows
View Count: 553
[2018-05-25 11:56:43] |
RoyM - Posts: 11 |
Hi, I want to ask that whether there are any methods to recover all my current data and graph settings if I wish to format and reinstall my windows? Thanks! |
[2018-05-25 18:51:48] |
Refer to the following: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System Be aware that you will need to copy your files out to another source first and then copy them back. So you will not be following the instructions exactly as they are written. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-25 18:53:27
