Date/Time: Fri, 24 May 2024 06:57:24 +0000
[Programming Help] - How do I import custom .zip file studies
View Count: 734
[2018-05-24 20:58:29] |
User371226 - Posts: 2 |
I have 2 .zip files. Infinity walked me thru opening them and putting them on my Desktop. Then I put them in :C Drive Sierra/Transact/MA file. But, they do not appear in Studies. How do I import them?? Thanks
[2018-05-24 21:03:22] |
You first have to extract the files contained within them. What are the file extensions of the files contained within them?
[2018-05-24 21:39:51] |
They are .zip files. Will they work? Importable?
[2018-05-24 21:50:35] |
Not as zip files. You first need to extract the files within them.
