Date/Time: Fri, 03 May 2024 09:05:18 +0000
Price display format ES and NQ with .25
View Count: 1339
[2013-10-10 23:52:21] |
User73583 - Posts: 3 |
My ES price shows as 168125, for example. How do I make it 1681.25? My current settings: Price display format = 1, tick size 25.00000, and volume at price multiplier = 1 |
Attachment Deleted. Capture.JPG / V - Attached On 2013-10-10 23:51:57 UTC - Size: 90.7 KB - 422 views |
[2013-10-11 00:05:51] |
ganz - Posts: 1048 |
User73583 Decimal point in DOM price |
[2013-10-11 00:31:33] |
Sorry, that does not help. Price still displays large number, except now it's 167725.00 I understand Sierra Chart engineers reluctance to change something, but they are not traders. A trader needs to make a quick decision without being bugged down by confusing number display. Date Time Of Last Edit: 2013-10-11 00:32:47
[2013-10-11 00:44:34] |
You need to update to the latest version of Sierra Chart by selecting Help >> Download Current Version. And then follow the CTS T4 FIX instructions here: https://www.sierrachart.com/index.php?l=doc/CTS_T4.php#UsingFIX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-11 00:55:51] |
Awesome, that worked. Thank you very much!
