Date/Time: Sat, 04 May 2024 04:15:55 +0000
Version 1750 - Copy Chart only in black and white
View Count: 726
[2018-05-24 14:35:28] |
nosast2 - Posts: 73 |
Since I updated to the current version 1750 I noticed, that when I copy a chart with the function Edit/Copy Chart Image it is only black and white. Using 1747 before it was coloured. Is there a new setting that needs to be adjusted? Thanks in advance. |
[2018-05-24 18:22:14] |
We will look into this.
[2018-05-25 07:37:05] |
nosast - Posts: 290 |
I'm having the same issue after updating.
[2018-05-25 08:52:35] |
This will be resolved with version 1751 which we will try to release today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-25 08:52:45
