Date/Time: Sat, 18 May 2024 18:04:35 +0000
Draw Volume Profile version 1750
View Count: 554
[2018-05-24 13:17:48] |
User99934 - Posts: 227 |
Draw volume profile button did not work in 1750. I rolled back to 1749 and its OK.
[2018-05-24 17:09:02] |
We will check on this.
[2018-05-24 17:39:45] |
This is now resolved. Update again by following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
