Date/Time: Fri, 17 Apr 2026 16:15:49 +0000
No DATA
View Count: 1636
| [2013-10-10 21:15:13] |
| User68895 - Posts: 2 |
OK I did the FIX you suggested to a friend of mine for Sierra and TOP STEP still not getting a symbol list I was finaly able to connect however I have no instruments at all Please advise thanks Maria |
| [2013-10-10 21:45:21] |
Select Global Settings >> Symbol Settings. Press the Full Reset button. Wait for the Symbols list to fill and then press OK.
| [2013-10-10 21:46:46] |
We can see you are running an older Sierra Chart version. You must update to the newest version to use the FIX connection for CTS T4. Select Help >> Download Current Version to update. Once again you MUST update.
