Date/Time: Tue, 30 Apr 2024 12:03:03 +0000
Request for more cumulative delta data and spreads
View Count: 693
[2018-05-24 02:02:20] |
User312162 - Posts: 40 |
I use CQG and often plot the curve, spreadsm and cumulative delta for contracts that are further out that end of 2019. Most futures data stops showing on a intraday basis after 2018. For example, I am trying to plot the cumulative delta for Crude Oil Decemeber 2018, 2019, and 2020 contracts but the only data I can pull is 2018. Thanks |
[2018-05-24 04:40:58] |
We will set this up before Monday.
[2018-06-14 06:43:45] |
Did this ever get setup for further dated futures contracts?
[2018-06-14 10:51:31] |
Yes this was done. Contracts out to this one are now maintained and listed: F.US.CLEK21 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
