Date/Time: Sat, 18 May 2024 18:02:47 +0000
Candles trade through Y-Axis LABELS
View Count: 611
[2018-05-24 01:01:16] |
User481114 - Posts: 17 |
Is there anyway to offset the X-Axis viewing of candles,they trade "through" the Y-Axis labels....Cannot find a solution in any type of chart viewing setup...No way to offset the X-Axis like 50-100 pixels so that candles don't get lost in Y-Axis labels? File attached...would be nice to shift "time" slightly to the left. Very crowded in there...somewhat of a nuisance always manually moving the chart over.. Thanks |
SierraSupp1.jpg / V - Attached On 2018-05-24 01:01:04 UTC - Size: 70.85 KB - 258 views |
[2018-05-24 05:05:38] |
Refer to: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#FillSpace Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
