Date/Time: Fri, 24 May 2024 06:57:33 +0000
Way to remove Hidden Sub Graph Studies from Placeholder?
View Count: 717
[2018-05-23 14:54:08] |
Xfanman1 - Posts: 320 |
When I have multiple subgraph studies on my chart, I normally only display one or 2 and have others hidden but referenced for different strategy alerts. The problem is, even though they are hidden, when I attempt to add or move another study, those hidden studies appear to still occupy an invisible placeholder in that position on the chart. This often causes alignment/spacing problems if I try to display, for example the Subgraph #2, with Subgraph #5 right next to one another. Is this expected behavior and is there anything I can do apart from reorder my subgraph study numbers whenever I want to compare different subgraph studies on my charts? Thanks much....Scott Date Time Of Last Edit: 2018-05-23 14:58:14
[2018-05-23 18:57:10] |
Not sure that we can do anything better to help with this. We do remember looking into this previously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
