Date/Time: Sat, 18 May 2024 13:23:05 +0000
Avoid more than 1 entry signal in the same bar if the Exit Signal appears in same bar
View Count: 588
[2018-05-23 14:30:19] |
User252419 - Posts: 235 |
Is there any easy way in spreadsheets to avoid more than 1 entry/exit signal in the same bar if the Entry/Exit Signal appears in same bar? I've played with Last Entry/Exit DateTime but it is extremely messy. Thank you Date Time Of Last Edit: 2018-05-23 18:38:35
[2018-05-23 21:50:50] |
Yes, this is controlled through this particular Input: https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#OncePerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-23 21:52:09
