Date/Time: Sat, 18 May 2024 18:02:41 +0000
Control Bar
View Count: 1050
[2018-05-22 16:04:15] |
User00111 - Posts: 111 |
I have two Sierra installations on my computer I have customized the Control Bar and I want to duplicate it in the other Sierra application. How can I do it |
[2018-05-22 20:20:03] |
Refer to the documentation here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation You want the file Sierra3.cfg as noted in Step 5 of the instructions above. Note that this will not only copy the Control Bar configurations, but also all your Global Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-23 09:07:53] |
I copy in the new Sierra installation the file Sierra3.cfg and I did the procedure in point 9 and 10. The Control bar and settig they have been copied (What I wanted) I went into the Global Setting / Data / Trade Service Setting and I changed it to the trading account, but mine always appears this message that I attach to you. Let me know what I have to do ? --- Antonio |
Message Log.txt - Attached On 2018-05-23 09:01:03 UTC - Size: 25.07 KB - 251 views |
[2018-05-23 18:05:05] |
In regards to these messages: Listening socket (632). Port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Di norma รจ consentito un solo utilizzo di ogni indirizzo di socket (protocollo/indirizzo di rete/porta). | 2018-05-23 10:58:53 *
Listening socket (632). Port 0 | Closed. | 2018-05-23 10:58:53 DTC Protocol Server failed to start listening on port 11099. | 2018-05-23 10:58:53 * Refer to: http://www.sierrachart.com/index.php?page=doc/NewInstance.php#ResolvingDTCProtocolServerPortNumberConflicts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
