Date/Time: Sat, 18 May 2024 09:05:36 +0000
Current Version
View Count: 1121
[2018-05-19 15:24:27] |
User223734 - Posts: 101 |
1)Please advise the no. of the current version? 2)When I select "Download Current Version", it doesn't work. I can only download prerelease version which is 1748. |
[2018-05-19 16:26:11] |
The current version is now 1748. We apologize for the issue. This has been resolved. Try installing Sierra Chart again using the same method you did previously.
