Date/Time: Sat, 18 May 2024 07:58:32 +0000
Symbol is unknown
View Count: 1198
[2018-05-17 17:00:21] |
User198180 - Posts: 1 |
When I join the IB TWS, a panel appears with the inscription: "symbol is unknown. click for ..." I have TFM8-FUT-NYBOT (Russel 2000 e-mini) and I do not have data in my charts. Where is the error?
[2018-05-17 18:03:59] |
That is an old symbol. You need to use: RTY-201806-GLOBEX-USD. You will see it listed in File >> Find Symbol >> Futures.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-17 18:05:17
