Date/Time: Sat, 18 May 2024 06:48:55 +0000
setting fixed size of subgraf region
View Count: 1031
[2018-05-16 11:28:00] |
User30743 - Posts: 364 |
hi, is it possible to somehow set a fixed size of a subgraph region where i draw my acsil studie? i mean, i would like to do it directly in the code, so that after loading the study into chart, the default settings will be immediately how it is supposed to be (see image 2). now, when i load it, it looks like in the picture 1, and i need to manually set it up through range scale. |
sc-subgraph1.png / V - Attached On 2018-05-16 11:27:23 UTC - Size: 57.09 KB - 317 views sc-subgraph2.png / V - Attached On 2018-05-16 11:27:39 UTC - Size: 33.76 KB - 294 views |
[2018-05-16 12:22:00] |
User553714 - Posts: 184 |
+1 I too would find this very useful if added. |
[2018-05-16 18:38:04] |
You need to use a User Defined Scale: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scScaleRangeTop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-17 09:55:05] |
ok, i will try out. one more thing. why is it not possible to draw different subgraphs into different chart regions? |
