Date/Time: Mon, 06 May 2024 08:38:59 +0000
Drawing Tool Feedback/Question
View Count: 1333
[2013-10-10 11:37:58] |
infpz - Posts: 826 |
For us "drawers", something that I have found very useful when using draw tools is a feature called redraw (or redraw)... it like the 'undo' feature in most image editing software used to 'undelete' the last deleted draw tool on a chart (or in a list). I have noticed that an "undelete" button feature would be most helpful when using the " Manage Chart Drawings " under the tools menu option. I have accidentally deleted sets of drawings in this window especially when 1 chart window is used to view different instruments and your trying to clean up just a few drawings... Also wish there was a tool like an "ABC Projection tool" ... its a 3 click tool where one would click to draw a line (A), click to draw wave B and click... to have line C (wave C) project the same slope A to a % of A (ie fibs, etc)... other options for additional legs might be handy for some as well... Ensign has a handy version of this tool. fwiw. |
[2013-10-10 15:41:08] |
Use Edit >> Undo Chart Drawing. Here is the drawing tool you are looking for: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#RetracementExpansionProjection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-10 16:45:19] |
the Projection tool draws C vertically... not sloping 'with' A slope... I was looking for this see attached image... it can be used as a timing tool (space) as well as Price projection tool... |
