Date/Time: Wed, 15 May 2024 14:23:55 +0000
sc.GetStudyPersistentFloatFromChartStudy not compiling
View Count: 708
[2018-05-15 07:35:59] |
Marmany - Posts: 303 |
Recently updated to v1744, noted in the online Manual that sc.GetStudyPersistentFloatFromChart is now called sc.GetStudyPersistentFloatFromChartStudy. So renamed all uses of this and the "Int" version accordingly. The study failed to compile with Remote Build error: 'struct s_sc' has no member named 'GetStudyPersistentFloatFromChartStudy'. Reverted to old nomenclature and compiled OK. Therefore I have no problem, but would be grateful if you could clarify. |
[2018-05-15 18:07:22] |
We apologize for this. Apparently the documentation was not properly updated. We are checking on this now.
[2018-05-15 21:36:11] |
Documentation has been corrected
