Date/Time: Sat, 18 May 2024 04:54:27 +0000
BID Suffix
View Count: 616
[2018-05-15 07:24:34] |
ElmStreetTrader - Posts: 48 |
Hi there, When using the -BID suffix with CFD/Forex symbols, is there a way to display the BID price on the price ladder/scale instead of the BID/ASK average? |
[2018-05-15 18:21:26] |
We have to look into why the average price is used in this case for the last trade price. For now what we recommend you do is use the Bid and Ask Prices study: Bid & Ask Prices You then need to enable the Value Label for the Bid price and set the alignment to Right Edge: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#NameValueLabels You will also want to add space on the right side of the chart: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#FillSpace Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-17 09:03:18] |
Will you update this thread once you have looked into this?
[2018-05-17 09:17:07] |
No. It is going to be a while before we look into this. We would not put any reliance on this.
