Date/Time: Tue, 30 Apr 2024 03:40:56 +0000
Difference in POC, VAH and VAL between Volume Value Area Lines study and VbP study
View Count: 1455
[2018-05-15 02:33:10] |
User106180 - Posts: 88 |
There is a difference in the POC, VAH and VAL lines between the Volume Value Area Lines study and VbP study. Both are set to 'Draw Developing Value Area Lines', and 'Ticks per Volume Bar' of 2. All other settings appear to be consistent between the two studies as well. Please see attached chartbook which has these two studies. The difference is particularly noticeable for the day 5-10. Why is there a difference between the two, they should be the same? Thank you. Study links: Volume Value Area Lines - Volume Value Area Lines Volume by Price - Volume By Price Study |
Attachment Deleted. SC.Cht - Attached On 2018-05-15 02:31:55 UTC - Size: 39.38 KB - 326 views |
[2018-05-15 04:19:35] |
We are looking into this. It appears like this issue has something to do with a slight rounding error because of the Ticks per Volume Bar being set to 2. In any case, we will solve it.
[2020-07-03 17:00:47] |
User882670 - Posts: 15 |
I have similar problem but with Value Area Lines (not volume). In TPO study - I've selected calculation based on TPO. Value area high and low are different than in TPO Value Area Lines study |
[2021-07-08 19:00:05] |
Ves - Posts: 1 |
I'm seeing the same thing. All settings equal the POC and Value Area Low/High are different for TPO chart and bar chart with a Volume per Price study. See screenshot.
