Date/Time: Tue, 14 May 2024 00:04:38 +0000
[User Discussion] - 6E/M6E tool drawing issue
View Count: 975
[2018-05-15 01:25:15] |
Rrrracer - Posts: 20 |
Hello, I am charting with symbol 6E, and trade/current quote symbol M6E. 6E tick size is 0.00005, and M6E tick size is 0.0001; this presents a problem with using tools to draw, because of the difference I am unable to move a drawing to a 0.00005 position; they jump in 0.0001 increments. I tried changing the tick size to 0.00005 which works, but then occasionally presents problems when placing orders through the chart/DOM since those prices do not exist in M6E. Is there a way to retain 0.0001 tick size for trading, while being able to draw in 0.00005 increments? Currently the only way I can make them display correctly is to go into Chart Drawing Properties and manually change the anchors to the correct increment. Thank you. |
[2018-05-15 23:23:41] |
I see this has been labeled User Discussion, not sure why... so no love from SC developers on this?
[2018-05-16 03:14:55] |
This is definitely something we cannot help with.
