Date/Time: Sat, 27 Apr 2024 19:07:53 +0000
Daily OHLC how to set p-GLOBEX Session
View Count: 1782
[2018-05-14 16:20:10] |
Jia T P R - Posts: 26 |
Good Day, i would like to set the p-GLOBEX Session (Yesterday High, Low, Open, Close 14:20-22:00) in a Daily 24H Chart. I have opened a normally Chart 6E Nr.1, then added the Study Daily OHLC. I have put everything on No except Daily Chart number =6 and Reference Days Back 2. Number of Days to Calculate 50 standart (look at Attached Picture). The second Chart i opened has the Nr.6 and i have set the Time from 14:20-22:00. Best https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19231 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=19232 |
[2018-05-14 17:03:01] |
This we do not understand: p-GLOBEX Session (Yesterday High, Low, Open, Close 14:20-22:00) in a Daily 24H Chart.
So the Daily 24H Chart is 1 day per bar? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-14 17:03:09
[2018-05-15 06:41:25] |
The Main Chart is Nr 1 and set to 10Range per Bar and set 0:00-23:59:59. The second Chart is Nr 6 and set to 5m and set 14:20-22:00. |
[2018-05-15 19:43:00] |
What we recommend you do is use the High/Low for Time Period - Extended study: High/Low for Time Period - Extended You will want to make sure that the Session Times on the chart you use this study with, are from 14:20:00 to 14:19:59: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-15 19:43:41
[2018-05-17 07:48:35] |
It works, until its 14:20 in my Country, then it is not stable anymore and making a new Price-Line what is totally logical ^^. Possible to have this inside for good from the yesterday Session for 24 Hours? Can i also Include a Second Session in my Chart Nr1 or only one? |
[2018-05-17 19:05:20] |
We are not really understanding what you mean, but what time zone is the chart set to and we will prepare an example for you. To determine what the time zone is, refer to: Time Zone Setting Can i also Include a Second Session in my Chart Nr1 or only one? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-17 19:06:21
[2018-05-18 07:01:53] |
In my primary Chart nr. 1 i ave set the Time from 14:20 to 14:19:59 so i can have the Globex Session. What is if i want to put in a second Session High or Low, it is going to Show it to me also from 14:20, because i cant set the Time ^^ The London Session from yesterday 9 to 17:30 i would like to add (High and Low in the same Chart ^^). |
[2018-06-09 19:58:53] |
I tried to work with "Daily OHLC" and put No at "use this Intraday Chart" and the Chart Number of another Chart where i have set the Session Times. Sadly it doesnt work. Im really frustrated. If i use on my primary Chart the Time 14:20-14:19:59 my Indicator is not working right (Vwap Daily) because i need to set a specific time. |
[2018-06-12 21:34:34] |
Sorry for the late reply. We are sorry that we just do not fully understand what you want to do from the back and forth we have had. It is best to simply start over and have you tell us what you want to accomplish. Keep it simple and to the point. We can then work to create either a Studies Collection or a Chartbook for you that is setup the way you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-19 13:39:01] |
Attached is an example Chartbook using High Low for Time Period - Extended. Follow the instructions here to use this Chartbook: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-19 13:39:42
OvernightSessionHighLow.Cht - Attached On 2018-06-19 13:38:49 UTC - Size: 30 KB - 238 views |
